Atte. ADAN
[Solucionado] Programa para reparar cluster dañados del Disco Duro
31/5/2007 02:15AM
Atte. ADAN
02/6/2007 02:13AM
Puedes encontrarlo por Ares. O busca en google.
Disfrutalo. Espero te ayude.
02/6/2007 02:25AM
Partition Tools:
- Partition Magic Pro 8.05 - Best software to partition hard drive
- Acronis Disk Director Suite 9.0.554 - Popular disk management functions in a single suite
- Paragon Partition Manager 7.0.1274 - Universal tool for partitions
- Partition Commander 9.01 - The safe way to partition your hard drive,with undo feature
- Ranish Partition Manager 2.44 - a boot manager and hard disk partitioner.
- The Partition Resizer v1.3.4 - move and resize your partitions in one step and more.
- Smart Fdisk 2.05 - a simple harddisk partition manager
- SPecial Fdisk 2000 - SPFDISK a partition tool.
- eXtended Fdisk 0.9.3 - XFDISK allows easy partition creation and edition
- GDisk 1.1.1 - Complete replacement for the DOS FDISK utility and more.
- Super Fdisk 1.0 - Create, delete, format partitions drives without destroying data
Disk Clone Tools:
- ImageCenter 5.6 (Drive Image 2002) - Best software to clone hard drive
- Norton Ghost 11.0 - Similar to Drive Image (with usb/scsi support)
- Acronis True Image 8.1.945 - Create an exact disk image for complete system backup and disk cloning.
- Partition Saver 3.30 - A tool to backup/restore partitions.
- COPYR.DMA Build013 - A Tool for making copies of hard disks with bad sectors
Antivirus Tools:
- F-Prot Antivirus 3.16f (1003) - Very good virus scanner (with ntfs support and easy to use menu)
- McAfee Antivirus 4.40 (1003) - a virus scanner (with ntfs support and easy to use menu)
Recovery Tools:
- Active Partition Recovery 3.0 - To Recover a Deleted partition.
- Active Uneraser 3.0 - To recover deleted files and folders on FAT and NTFS systems.
- Ontrack Easy Recovery Pro 6.10 - To Recover data that has been deleted/virus attack
- Winternals Disk Commander 1.1 - more than just a standard deleted-file recovery utility
- TestDisk 6.7b - Tool to check and undelete partition.
- Lost & Found 1.06 - a good old data recovery software.
- DiyDataRecovery Diskpatch 2.1.100 - An excellent data recovery software.
- Prosoft Media Tools 5.0 v1.1.2.64 - Another excellent data recovery software with many other options.
- PhotoRec 6.7b - File and pictures recovery Tool.
Testing Tools:
- System Speed Test 4.78 - it tests CPU, harddrive, ect.
- PC-Check 6.0 - Easy to use hardware tests
- Ontrack Data Advisor 5.0 - Powerful diagnostic tool for assessing the condition of your computer
- The Troubleshooter 7.02 - all kind of hardware testing tool
- PC Doctor 3.0 - a benchmarking and information tool
- Test Cpu/Video/Disk 5.6 - a tool to test cpu, video, and disk
- Test Hard Disk Drive 1.0 - a tool to test Hard Disk Drive
RAM (Memory) Testing Tools:
- DocMemory 3.1b - RAM Test utility
- GoldMemory 5.07 - RAM Test utility
- Memtest86+ 1.70 - PC Memory Test
Hard Disk Tools:
- Hard Disk Diagnostic Utilities
- Seagate Seatools Desktop Edition 3.02
- Western Digital Data Lifeguard Tools
- Western Digital Diagnostics (DLGDIAG) 5.04f
- Maxtor PowerMax 4.23
- Maxtor amset utility 4.0
- Maxtor(or any Hdd) Low Level Formatter 1.1
- Fujitsu HDD Diagnostic Tool 6.61
- Fujitsu IDE Low Level Format 1.0
- Samsung HDD Utility(HUTIL) 2.02
- Samsung Disk Diagnose (SHDIAG) 1.28
- IBM/Hitachi Drive Fitness Test 4.08
- IBM/Hitachi Feature Tool 2.03
- Gateway GwScan 3.15
- ExcelStor's ESTest 3.80
- MHDD 4.6
- WDClear 1.30
- Toshiba Hard Disk Diagnostic 2.00b
- SeaTools for Dos 1.08
- HDD Regenerator 1.51 - to recover a bad hard drive
- Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool.
- Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive.
- Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool.
- Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive.
- HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices
- SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer.
- Victoria 3.33 - a freeware program for low-level HDD diagnostics
System Information Tools:
- Aida16 2.14 - a system information tool, extracts details of all components of the PC
- PCI and AGP info Tool (1003) - The PCI System information & Exploration tool.
- System Analyser version 5.3p - View extensive information about your hardware
- Navratil Software System Information 0.59.14 - High-end professional system information tool
- Astra 5.31 - Advanced System info Tool and Reporting Assistant
- HwInfo 5.0.5 - a powerful system information utility
- PC-Config 9.33 - Complete hardware detection of your computer
- SysChk 2.46- Find out exactly what is under the hood of your PC
- CPU Identification utility v1.12 - Detailed information on CPU
- CTIA CPU Information - another CPU information tool
MBR (Master Boot Record) Tools:
- MBR Work 1.07b - a utility to perform some common and uncommon MBR functions
- MBR Tool 2.2.100 - backup, verify, restore, edit, refresh, remove, display, re-write...
- DiskMan4 - all in one tool for cmos, bios, bootrecord and more
- BootFix Utility - Run this utility if you get 'Invalid system disk'
- MBR SAVE / RESTORE 2.1 - BootSave and BootRest tools to save / restore MBR
- Boot Partition 2.60 - add Partition in the Windows NT/2000/XP Multi-boot loader
- Partition Table Doctor 3.0 - a tool to repair/modify mbr, bootsector, partition table
- Smart Boot Manager 3.7.1 - a multi boot manager
- Bootmagic 8.0 - This tool is for multi boot operating systems
- MBRWizard 2.0b - Directly update and modify the MBR (Master Boot Record)
BIOS / CMOS Tools:
- CMOS 0.93 - CMOS Save / Restore Tool
- BIOS Cracker 4.8 - BIOS password remover (cmospwd)
- BIOS Cracker 1.4 - BIOS password remover (cmospwc)
- BIOS Utility 1.35.0 - BIOS Informations, password, beep codes and more.
- !BIOS 3.20 - a powerfull utility for bios and cmos
- DISKMAN4 - a powerful all in one utility
- UniFlash 1.40 - bios flash utility
- Kill CMOS - a tiny utility to wipe cmos
- Award DMI Configuration Utility 2.43 - DMI Configuration utility for modifying/viewing the MIDF contents.
MultiMedia Tools:
- Picture Viewer 1.94 - Picture viewer for dos, supports more then 40 filetypes.
- QuickView Pro 2.57 - movie viewer for dos, supports many format including divx.
- MpxPlay 1.54 - a small Music Player for dos
Password Tools:
- Active Password Changer 3.0.420 - To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS)
- Offline NT/2K/XP Password Changer - utility to reset windows nt/2000/xp administrator/user password.
- Registry Viewer 4.2 - Registry Viewer/Editor for Win9x/Me/NT/2K/XP
- Registry Reanimator v1.02 - check and restore structure of the damaged registry files of NT/2K/XP
- NTPWD - utility to reset windows nt/2000/xp administrator/user password.
- ATAPWD 1.2 - Hard Disk Password Utility
NTFS Ext2FS, Ext3FS (FileSystems) Tools :
- NTFS Dos Pro 5.0 - To access ntfs partitions from Dos
- NTFS 4 Dos 1.4 - To access ntfs partitions from Dos
- Paragon Mount Everything 3.0 - To access NTFS, Ext2FS, Ext3FS partitions from dos
- NTFS Dos 3.02 - To access ntfs partitions from Dos
- EditBINI 1.01 - to Edit boot.ini on NTFS Partition
Dos File Managers:
- Volkov Commander 4.99 - Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander)
- Dos Command Center 5.1 - Classic dos-based file manager.
- File Wizard 1.35 - a file manager - colored files, drag and drop copy, move, delete etc.
- File Maven 3.5 - an advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable
- FastLynx 2.0 - Dos file manager with Pc to Pc file transfer capability
- LapLink 5.0 - the smart way to transfer files and directories between PCs.
- Dos Navigator 6.4.0 - Dos File Manager, Norton Commander clone but has much more features.
- Mini Windows 98 - Can run from Ram Drive, with ntfs support, Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip, .bzip2 .z .tar .cpio .rpm and .deb, Disk Defragmenter, Notepad /
RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
Other Tools:
- Ghost Walker 2003.793 - utility that changes the security ID (SID) for Windows NT, 2000 and XP
- DosCDroast beta 2 - Dos CD Burning Tools
- Universal TCP/IP Network 5.9.3 - MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 85
different network card drivers
Dos Tools:
- USB CD-Rom Driver 1 - Standard usb_cd.sys driver for cd drive
- Universal USB Driver 2 - Panasonic v2.20 ASPI Manager for USB mass storage
- SCSI Support - SCSI Drivers for Dos
- SATA Support - SATA Driver (gcdrom.sys) and JMicron JMB361 (xcdrom.sys) for Dos
- 1394 Firewire Support - 1394 Firewire Drivers for Dos
- Interlnk support at COM1 To access another computer from COM port
- Interlnk support at LPT1 - To access another computer from LPT port
Windows Tools:
- SpaceMonger 1.4 - keeping track of the free space on your computer
- Drive Temperature 1.0 - Hard Disk Drive temperature meter
- Disk Speed 1.0 - Hard Disk Drive Speed Testing Tool
- MemTest 1.0 - a Memory Testing Tool
- PageDfrg 2.32 - System file Defragmenter For NT/2k/XP
- WhitSoft File Splitter 4.5a - a Small File Split-Join Tool
- Ghost Image Explorer 11.0 - to add/remove/extract files from Ghost image file
- DriveImage Explorer 5.0 - to add/remove/extract files from Drive image file
- Drive SnapShot 1.37 - creates an exact Disk Image of your system into a file while windows is running.
- Active Undelete 5.1.010 - a tool to recover deleted files
- Restoration 2.5.14 - a tool to recover deleted files
- GetDataBack for FAT 2.31 - Data recovery software for FAT file systems
- GetDataBack for NTFS 2.31 - Data recovery software for NTFS file systems
- Unstoppable Copier 2.28 - Allows you to copy files from disks with problems such as bad sectors, scratches or that just give errors when reading data.
- Startup Control Panel 2.8 - a tool to edit startup programs
- Startup Monitor 1.02 - it notifies you when any program registers itself to run at system startup
- IB Process Manager 1.04 - a little process manager for 9x/2k, shows dll info etc.
- Pocket KillBox 2.0 - can be used to get rid of files that stubbornly refuse to allow you to delete them
- Unlocker 1.8.5 - This tool can delete file/folder when you get this message - Cannot delete file: Access is denied, The file is in use by another program etc.
- HijackThis 1.99 - a general homepage hijackers detector and remover and more
- RootkitRevealer 1.7 - Rootkit Revealer is an advanced patent-pending root kit detection utility.
- Silent Runners Revision 50 - A free script that helps detect spyware, malware and adware in the startup process
- Autoruns 8.61 - Displays All the entries from startup folder, Run, RunOnce, and other Registry keys, Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications,
auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers and much more which helps to remove nasty spyware/adware and viruses.
- Dial a Fix 0.60.0.24 - Fix errors and problems with COM/ActiveX object errors and missing registry entries, Automatic Updates, SSL, HTTPS, and Cryptography service (signing/verification)
issues, Reinstall internet explorer etc. comes with the policy scanner
- CurrPort 1.07 - displays the list of all currently opened TCP and UDP ports on your computer
- Unknown Devices 1.2 (1003) - helps you find what those unknown devices in Device Manager really are
- PCI 32 Sniffer 1.1 (1003) - device information tool (similar to unknown devices)
- NewSID 4.10 - utility that changes the security ID (SID) for Windows NT, 2000 and XP
- Double Driver 1.0 - Driver Backup and Restore tool
- DriverBackup! 1.0 - Another handy tool to backup drivers
- CPU-Z 1.39 -It gathers information on some of the main devices of your system
- CWShredder 2.19 - Popular CoolWebSearch Trojan Remover tool
- Winsock 2 Fix for 9x - to fix corrupted Winsock2 information by poorly written Internet programs
- XP TCP/IP Repair 1.0 - Repair your Windows XP Winsock and TCP/IP registry errors
- CCleaner 1.38.485 - Crap Cleaner is a freeware system optimization and privacy tool
- EzPcFix 1.0.0.16 - Helpful tool when trying to remove viruses, spyware, and malware
- Content Advisor Password Remover 1.0 - It Removes Content Advisor Password from Internet Explorer
- WinKeyFinder 1.0 - Allows you to View and Change Xp, Windows 2003 and .NET Product Keys
- Spybot - Search & Destroy 1.4 (1003) - Application to scan for spyware, adware, hijackers and other malicious software.
- SpywareBlaster 3.5.1 (1003) - Prevent the installation of spyware and other potentially unwanted software.
- Ad-Aware SE Personal 1.06 (1003) - find and remove spyware, adware, dialers etc. (a must have tool)
espero te sirva muchas gracias
